Ana içeriğe geç
Toshiba Satellite A305-S6848 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite A305-S6848 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Remove the 5.8mm Phillip's #0 screw with Phillip's #0 screwdriver while prying plastic covering up with metal spudger.
  2. Toshiba Satellite A305-S6848 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove plastic covering.
    • Pull up the silver tab to remove the hard drive from the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua E Hong
449 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G1
2 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Note: There are two hard drives in this machine. One has a single screw holding it in place within the compartment, and is very straightforward. The other has two screws. After removing the latter, the drive compartment pulls out, sliding over the now empty screw holes.
Kim McCoy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,160
