Ana içeriğe geç
Toshiba Satellite A305-S6848 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A305-S6848 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 2, 1 resimden 1.
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 3, 1 resimden 1.
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • The keyboard is held in by a locking strip between the screen and the keyboard.
  5. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 5, 1 resimden 1.
    • Use the metal spudger to pry out the right portion of the locking piece just above the DEL key.
  6. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 6, 1 resimden 1.
    • Use your hand to take out locking strip from the right portion that was pried out.
  7. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 7, 2 resimden 1. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 7, 2 resimden 2.
    • Use the Phillip's #0 screwdriver to take out the two 5.8 mm Phillip's #0 screws from the top right and left corners of the keyboard.
  8. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite A305-S6848 Keyboard Replacement: adım 8, 2 resimden 2.
    • Lift the keyboard up slightly. Use caution as the keyboard ribbon cable is still attached below the keyboard.
    • Disconnect the keyboard by flipping the locking clip upwards.
Sonuç
Joshua E Hong
449 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G1
2 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 600
