Ana içeriğe geç
Toshiba Satellite A305-S6848 LCD Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A305-S6848 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Close laptop and turn it upside down.
  2. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Move the left locking hatch to the left.
    • Hold the right spring latch to the right.
  3. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Carefully remove the battery from the laptop.
  4. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 1. Toshiba Satellite A305-S6848 LCD Screen Replacement, LCD Screen: adım 4, 2 resimden 2.
    • Remove the 6 rubber tabs on the housing using the metal spudger.
  5. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 5, 2 resimden 1. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Remove the six 5.8 mm screws using the Phillip's #0 screwdriver.
  6. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Pry out plastic housing on all sides.
  7. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 7, 2 resimden 1. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Pry out the bottom left and right locking pieces of the plastic housing with the metal spudger.
  8. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 8, 2 resimden 1. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 8, 2 resimden 2.
    • Remove the four 5.8 mm screws using the Phillip's #0 screwdriver.
  9. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 9, 1 resimden 1.
    • Remove the eight 6.5 mm screws on the left and right sides of the screen using the Phillip's #0 screwdriver.
  10. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 10, 2 resimden 1. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Pull the screen down.
    • Pull off tape and take our video connector.
  11. Toshiba Satellite A305-S6848 LCD Screen Replacement: adım 11, 1 resimden 1.
    • Remove cold cathode fluorescent light bulb connector.
Sonuç
Joshua E Hong
449 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team S8-G1, Johnson Fall 2017 Baylor, Team S8-G1, Johnson Fall 2017 üyesi
BU-JOHNSON-F17S8G1
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 20
Her zaman: 626
