Ana içeriğe geç
Toshiba Satellite A65-S126 Speaker Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A65-S126 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Toshiba Satellite A65-S126 Speaker Replacement: adım 2, 1 resimden 1.
    • Gently lift the battery out of the computer.
  3. Toshiba Satellite A65-S126 Speaker Replacement, Upper Assembly: adım 3, 1 resimden 1.
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Toshiba Satellite A65-S126 Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the WIFI module cover. It will pull right off.
  5. Toshiba Satellite A65-S126 Speaker Replacement: adım 5, 2 resimden 1. Toshiba Satellite A65-S126 Speaker Replacement: adım 5, 2 resimden 2.
    • Unplug the white and black wires from the WiFi module.
  6. Toshiba Satellite A65-S126 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Toshiba Satellite A65-S126 Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Toshiba Satellite A65-S126 Speaker Replacement: adım 8, 1 resimden 1.
    • Use the plastic opening tool to pry the two halves apart.
  9. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: adım 9, 2 resimden 1. Toshiba Satellite A65-S126 Speaker Replacement, Speaker: adım 9, 2 resimden 2.
    • Locate the plug for the speaker wires on the bottom of the laptop.
  10. Toshiba Satellite A65-S126 Speaker Replacement: adım 10, 1 resimden 1.
    • Unplug the speaker wire connector.
  11. Toshiba Satellite A65-S126 Speaker Replacement: adım 11, 1 resimden 1.
    • Remove the speakers by sliding them straight up. They should slide out with ease.
Sonuç
Cole Uhland
216 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-8, Forte Fall 2013 Cal Poly, Team 14-8, Forte Fall 2013 üyesi
CPSU-FORTE-F13S14G8
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 587
