Ana içeriğe geç
Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 3, 3 resimden 1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 3, 3 resimden 2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 3, 3 resimden 3.
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 5, 2 resimden 2.
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
Sonuç
Cassie Pickett
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G1, Bennett Spring 2017 Texas Tech, Team S8-G1, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G1
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 21
Her zaman: 584
