Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
Locate the two sliding tabs on either side of the battery.
Using both hands, place one finger on each tab and slide them to the sides and away from each other.
Pull the battery out, keeping the tabs pushed to the side.
Use a J00 bit to unscrew the single 4mm screw that leads to the RAM Memory compartment.
Pull apart the two metal tabs that are holding the RAM cards in place.
You will feel the card pop up from its held position, indicating it can safely be pulled out.
Use tabs on the sides of the bottom RAM card to release the RAM card.
Remove the bottom RAM card, just as the top RAM card was removed.
