Ana içeriğe geç
Toshiba Satellite A660-ST3NX2X Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A660-ST3NX2X Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 2, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 2, 2 resimden 2.
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 3, 3 resimden 1. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 3, 3 resimden 2. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 3, 3 resimden 3.
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: adım 4, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Unplug all devices and power down the computer completely.
    • Peel back all four circular stickers that are located at each corner of the computer frame.
    • A pair of fine point tweezers was used to complete this.
  5. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 5, 1 resimden 1.
    • Unscrew all four 5mm screws located underneath the stickers in each corner of the computer frame.
    • The computer frame should become more loose after the screws are removed.
  6. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 6, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 6, 2 resimden 2.
    • Pry the frame of the screen away from the computer.
    • A prying tool was used by inserting it in the crack between the frame and the screen and running it along the edges of the frame.
  7. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 7, 2 resimden 1. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 7, 2 resimden 2.
    • Unscrew the three black 4mm JIS screws on each side of the metal frame that is still attached to the side of the screen.
    • Only two screws are shown in the image.
    • The metal frame will completely separate from the computer screen.
  8. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 8, 3 resimden 1. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 8, 3 resimden 2. Toshiba Satellite A660-ST3NX2X Screen Replacement: adım 8, 3 resimden 3.
    • Position the screen in a way that the aluminum backing is exposed.
    • Peel off the metal-like attachment from the back of the screen.
Sonuç
Megan Murrell
322 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G1, Bennett Spring 2017 Texas Tech, Team S8-G1, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G1
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 22
Her zaman: 551
