Ana içeriğe geç
Toshiba Satellite A665-S5170 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: adım 2, 1 resimden 1.
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: adım 3, 3 resimden 1. Toshiba Satellite A665-S5170 Battery Replacement: adım 3, 3 resimden 2. Toshiba Satellite A665-S5170 Battery Replacement: adım 3, 3 resimden 3.
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chelsea Teague
385 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,233
