Ana içeriğe geç
Toshiba Satellite A665-S5170 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A665-S5170 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn the computer upside down so that the bottom of the laptop is facing up.
    • Position the laptop so that you are able to read the words printed on the labels on the bottom of the laptop from left to right, and so that the laptop's hard drive panel is in the upper right-hand corner of the bottom of the computer.
    • Using a Phillip’s head 0 screwdriver, remove the 2mm Phillips head screw on the right side of the cover of the hard drive panel by rotating it counter-clockwise.
  2. Toshiba Satellite A665-S5170 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite A665-S5170 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Insert something thin, such as your nail or a credit card, into the slot on the right side of the cover of the hard drive panel.
    • Pull your finger up to pop off the cover of the hard drive panel.
  3. Toshiba Satellite A665-S5170 Hard Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite A665-S5170 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Gently push down on the hard drive with your hand.
    • Still pressing down on the hard drive, move your hand to the right in order to slide the hard drive to the right and to disconnect it from the computer.
  4. Toshiba Satellite A665-S5170 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite A665-S5170 Hard Drive Replacement: adım 4, 2 resimden 2.
    • To pull out the hard drive, pinch the plastic tab attached to the right of the hard drive with your thumb and index finger.
    • Gently lift the hard drive from the panel by pulling up on the plastic tab.
Sonuç
Chelsea Teague
385 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Fall 2016 Baylor, Team 4-5, Williams Fall 2016 üyesi
BU-WILLIAMS-F16S4G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,925
