Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
Remove the two 3.67 mm screws from the top corners of the keyboard.
Remove the cable connecting the keyboard with the motherboard.
Lift up and remove the keyboard.
Gently pull the black and white wires out of the upper case.
Remove two 8.6 mm screws on the back corners of the laptop.
2 farklı kişi bu kılavuzu tamamladı.
