Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Make sure battery-lock is in the unlock position.
Slide button to the left.
Remove the two 5.62 mm screws from the optical drive cover.
Remove the optical drive cover.
A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
Using the inset divot, push the optical drive out of the laptop to remove.
Push the bottom left corner of the CD Drive until the drive protrudes from the case.
When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
Remove the two 3.67 mm screws from the top corners of the keyboard.
Remove the cable connecting the keyboard with the motherboard.
Lift up and remove the keyboard.
Gently pull the black and white wires out of the upper case.
Remove two 8.6 mm screws on the back corners of the laptop.
Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
Then remove the fourteen 8.6 mm screws from the bottom of the case.
Use the screwdriver to remove six 8.6 mm screws from the top of the case.
Use the plastic opening tool to remove the two speaker wire connectors and the trackpad connector from the motherboard.
With the plastic opening tool, pry around the entire laptop to separate the upper case.
Using the Phillips Screwdriver, remove the two 8.6 mm screws from the front edge of the motherboard.
Remove the four screws holding the ports to the rear panel using the 3/16" Wrench.
Lift up on the front edge of the motherboard while gently prying the case away from the ports on the right side of the computer.
Repeat with the left side.
Lift the motherboard's front edge up and then slide it forward.
Remove cables connecting the fans with the motherboard.
Turn over the motherboard.
Remove the four silver screws with a Phillips screwdriver.
Lift the fans up to remove them from the motherboard.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thanks Garrett...
Your time and effort in putting this guide together is much appreciated (and helpful!)
Rick
