Ana içeriğe geç
Toshiba Satellite A75-S226 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite A75-S226 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  2. Toshiba Satellite A75-S226 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite A75-S226 Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  3. Toshiba Satellite A75-S226 Keyboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite A75-S226 Keyboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite A75-S226 Keyboard Replacement: adım 3, 3 resimden 3.
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  4. Toshiba Satellite A75-S226 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  5. Toshiba Satellite A75-S226 Keyboard Replacement: adım 5, 3 resimden 1. Toshiba Satellite A75-S226 Keyboard Replacement: adım 5, 3 resimden 2. Toshiba Satellite A75-S226 Keyboard Replacement: adım 5, 3 resimden 3.
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
Sonuç
Garrett Gudgel
763 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-43, Amido Fall 2010 Cal Poly, Team 4-43, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G43
5 Üyeler
39 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 4,300
