Ana içeriğe geç
Toshiba Satellite A75-S226 Speakers Replacement
Neye ihtiyacın var
  1. Toshiba Satellite A75-S226 Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure battery-lock is in the unlock position.
    • Slide button to the left.
  2. Toshiba Satellite A75-S226 Speakers Replacement: adım 2, 1 resimden 1.
    • Lift battery out of the computer.
  3. Toshiba Satellite A75-S226 Speakers Replacement, Optical Drive: adım 3, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, Optical Drive: adım 3, 2 resimden 2.
    • Remove the two 5.62 mm screws from the optical drive cover.
  4. Toshiba Satellite A75-S226 Speakers Replacement: adım 4, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 4, 2 resimden 2.
    • Remove the optical drive cover.
    • A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
  5. Toshiba Satellite A75-S226 Speakers Replacement: adım 5, 1 resimden 1.
    • Using the inset divot, push the optical drive out of the laptop to remove.
  6. Toshiba Satellite A75-S226 Speakers Replacement, CD Drive: adım 6, 3 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, CD Drive: adım 6, 3 resimden 2. Toshiba Satellite A75-S226 Speakers Replacement, CD Drive: adım 6, 3 resimden 3.
    • Remove the 8.6 mm screw.
  7. Toshiba Satellite A75-S226 Speakers Replacement: adım 7, 3 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 7, 3 resimden 2. Toshiba Satellite A75-S226 Speakers Replacement: adım 7, 3 resimden 3.
    • Push the bottom left corner of the CD Drive until the drive protrudes from the case.
    • When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
  8. Toshiba Satellite A75-S226 Speakers Replacement, Wi-Fi/Memory Cover: adım 8, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, Wi-Fi/Memory Cover: adım 8, 2 resimden 2.
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  9. Toshiba Satellite A75-S226 Speakers Replacement: adım 9, 1 resimden 1.
    • Lift up the cover panel using a plastic opening tool.
  10. Toshiba Satellite A75-S226 Speakers Replacement, Wi-Fi Card: adım 10, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, Wi-Fi Card: adım 10, 2 resimden 2.
    • Remove the 5.64 mm screw from the bottom of the crossing bar.
    • Remove the crossing bar.
  11. Toshiba Satellite A75-S226 Speakers Replacement: adım 11, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 11, 2 resimden 2.
    • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
  12. Toshiba Satellite A75-S226 Speakers Replacement: adım 12, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 12, 2 resimden 2.
    • Use fingers to push the clips away from memory card.
  13. Toshiba Satellite A75-S226 Speakers Replacement: adım 13, 1 resimden 1.
    • Use fingers to remove the Wi-Fi card.
  14. Toshiba Satellite A75-S226 Speakers Replacement, Keyboard: adım 14, 3 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, Keyboard: adım 14, 3 resimden 2. Toshiba Satellite A75-S226 Speakers Replacement, Keyboard: adım 14, 3 resimden 3.
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  15. Toshiba Satellite A75-S226 Speakers Replacement: adım 15, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 15, 2 resimden 2.
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  16. Toshiba Satellite A75-S226 Speakers Replacement: adım 16, 3 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 16, 3 resimden 2. Toshiba Satellite A75-S226 Speakers Replacement: adım 16, 3 resimden 3.
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  17. Toshiba Satellite A75-S226 Speakers Replacement: adım 17, 1 resimden 1.
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  18. Toshiba Satellite A75-S226 Speakers Replacement: adım 18, 3 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 18, 3 resimden 2. Toshiba Satellite A75-S226 Speakers Replacement: adım 18, 3 resimden 3.
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
  19. Toshiba Satellite A75-S226 Speakers Replacement, Display Assembly: adım 19, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, Display Assembly: adım 19, 2 resimden 2.
    • Remove the 3.76mm screw from the ground wire.
  20. Toshiba Satellite A75-S226 Speakers Replacement: adım 20, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 20, 2 resimden 2.
    • Use the plastic opening tool to remove the wire.
  21. Toshiba Satellite A75-S226 Speakers Replacement: adım 21, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 21, 2 resimden 2.
    • Gently pull the black and white wires out of the upper case.
    • Do not pull the wire too much, or you can damage the wire.
  22. Toshiba Satellite A75-S226 Speakers Replacement: adım 22, 1 resimden 1.
    • Remove the 8.6 mm screw on left side of upper case.
  23. Toshiba Satellite A75-S226 Speakers Replacement: adım 23, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 23, 2 resimden 2.
    • Remove two 8.6 mm screws on the back corners of the laptop.
  24. Toshiba Satellite A75-S226 Speakers Replacement: adım 24, 1 resimden 1.
    • Lift up the display assembly to remove it.
  25. Toshiba Satellite A75-S226 Speakers Replacement, Upper Case: adım 25, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement, Upper Case: adım 25, 2 resimden 2.
    • Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
    • Then remove the fourteen 8.6 mm screws from the bottom of the case.
  26. Toshiba Satellite A75-S226 Speakers Replacement: adım 26, 1 resimden 1.
    • Use the screwdriver to remove six 8.6 mm screws from the top of the case.
  27. Toshiba Satellite A75-S226 Speakers Replacement: adım 27, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 27, 2 resimden 2.
    • Use the plastic opening tool to remove the two speaker wire connectors and the trackpad connector from the motherboard.
  28. Toshiba Satellite A75-S226 Speakers Replacement: adım 28, 1 resimden 1.
    • With the plastic opening tool, pry around the entire laptop to separate the upper case.
  29. Toshiba Satellite A75-S226 Speakers Replacement: adım 29, 1 resimden 1.
    • Lift up the upper case to remove.
  30. Toshiba Satellite A75-S226 Speakers Replacement, Speakers: adım 30, 1 resimden 1.
    • Locate the two speakers on the underside of the upper case.
  31. Toshiba Satellite A75-S226 Speakers Replacement: adım 31, 2 resimden 1. Toshiba Satellite A75-S226 Speakers Replacement: adım 31, 2 resimden 2.
    • Remove two screws from each speaker with the Phillips Screwdriver.
  32. Toshiba Satellite A75-S226 Speakers Replacement: adım 32, 1 resimden 1.
    • Lift the speakers from the case to remove.
Sonuç
Garrett Gudgel
763 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-43, Amido Fall 2010 Cal Poly, Team 4-43, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S4G43
5 Üyeler
39 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 4,558
