Ana içeriğe geç
Toshiba Satellite C50D-A Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C50D-A Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Click button 1 to the unlocked position.
    • This button will have a 1 by it.
  2. Toshiba Satellite C50D-A Optical Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C50D-A Optical Drive Replacement: adım 2, 2 resimden 2.
    • Push and hold button 2 to the left.
    • As you push button 2 to the left position, simultaneously lift up the battery pack.
    • This button will have a 2 by it.
  3. Toshiba Satellite C50D-A Optical Drive Replacement, Lower Case: adım 3, 2 resimden 1. Toshiba Satellite C50D-A Optical Drive Replacement, Lower Case: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the eleven 2.5mm screws.
  4. Toshiba Satellite C50D-A Optical Drive Replacement: adım 4, 1 resimden 1.
    • Remove the one 2.5mm Phillips #1 middle plate screw.
  5. Toshiba Satellite C50D-A Optical Drive Replacement: adım 5, 1 resimden 1.
    • Lift up the middle vent panel.
    • Set the panel to the side.
  6. Toshiba Satellite C50D-A Optical Drive Replacement: adım 6, 3 resimden 1. Toshiba Satellite C50D-A Optical Drive Replacement: adım 6, 3 resimden 2. Toshiba Satellite C50D-A Optical Drive Replacement: adım 6, 3 resimden 3.
    • Using the plastic opening tool, remove the outer panel and set to the side.
    • Be careful not to break the back of the computer.
  7. Toshiba Satellite C50D-A Optical Drive Replacement, Optical Drive: adım 7, 1 resimden 1.
    • Locate the opticaldrive and find where it is slotted into the motherboard.
    • Be careful not to break the attachment site.
  8. Toshiba Satellite C50D-A Optical Drive Replacement: adım 8, 1 resimden 1.
    • Gently lift up the optical drive at a slight angle, and pull it towards you to remove it.
Sonuç
Bir Yorum
This is an awful guide - it does not tell you that there are another 6 or more screws under the keyboard - this is bad.
Books2Africa Tech Team - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 932
