Giriş
This guide will show you how to successfully replace your Toshiba Satellite laptop's battery. It is a very simple process that does not involve the use of tools. Located on the back of the laptop, you can detach it without removing anything else.
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
Bir başkası bu kılavuzu tamamladı.
