Ana içeriğe geç
Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: adım 1, 3 resimden 1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: adım 1, 3 resimden 2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, Hard Drive: adım 1, 3 resimden 3.
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  3. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: adım 3, 2 resimden 1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: adım 3, 2 resimden 2.
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  4. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: adım 4, 2 resimden 1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement, CPU Cooling Fan: adım 4, 2 resimden 2.
    • Unscrew all 15 of the screws in the back cover of the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  5. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: adım 5, 3 resimden 1. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: adım 5, 3 resimden 2. Toshiba Satellite C55-A5100 CPU Cooling Fan Replacement: adım 5, 3 resimden 3.
    • Unscrew the two silver screws attaching the fan to the case.
    • Unplug the power connector for the fan.
    • Pull the fan up out of the slot.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Rei Rutkowski
184 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S8-G8, Wilson Fall 2018 IUPUI, Team S8-G8, Wilson Fall 2018 üyesi
IUPUI-WILSON-F18S8G8
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
The one I disassembled didn’t have a screw under the battery bay, but did have one under the HDD bay, just as described by a comment in the charge port replacement guide.
Luis Alejandro Araúz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 1,054
