Ana içeriğe geç
Toshiba Satellite C55-A5100 Charging Port Jack Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Battery: adım 1, 1 resimden 1.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 2, 1 resimden 1.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: adım 3, 3 resimden 1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: adım 3, 3 resimden 2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 4, 1 resimden 1.
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 5, 1 resimden 1.
    • Remove the disc drive from the device.
  6. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: adım 6, 3 resimden 1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: adım 6, 3 resimden 2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Hard Drive: adım 6, 3 resimden 3.
    • Place the laptop with the bottom facing up.
  7. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 7, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  8. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 8, 2 resimden 2.
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
  9. Toshiba Satellite C55-A5100 Charging Port Jack Replacement, Charging Port Jack: adım 9, 1 resimden 1.
    • Unscrew all 15 screws that attach the back cover to the laptop.
    • Carefully pry the back cover off the laptop using the prying tools, starting from the hard drive side.
  10. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 10, 3 resimden 1. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 10, 3 resimden 2. Toshiba Satellite C55-A5100 Charging Port Jack Replacement: adım 10, 3 resimden 3.
    • Locate the charging jack. Then carefully pull straight up.
    • Unplug the connector by pulling it towards the charging port side of the case, then carefully guide the wires away from the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rei Rutkowski
184 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S8-G8, Wilson Fall 2018 IUPUI, Team S8-G8, Wilson Fall 2018 üyesi
IUPUI-WILSON-F18S8G8
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Hi. Correction on Step 9. Aside from the 15 black screws, I had to unscrew one silver screw. It sits right under the HDD.
Everything else was perfectly described.
Isidro B. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 35
Her zaman: 1,611
