Ana içeriğe geç
Toshiba Satellite C55-A5100 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Toshiba Satellite C55-A5100 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Place the laptop with the bottom facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the 8mm screw that is holding the hard drive in place.
  5. Toshiba Satellite C55-A5100 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55-A5100 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Use your finger to lift the hard drive up.
    • Pull out the hard drive to the right.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,027
