Ana içeriğe geç
Toshiba Satellite C55-A5100 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5100 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Keyboard Replacement: adım 2, 1 resimden 1.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Toshiba Satellite C55-A5100 Keyboard Replacement: adım 4, 1 resimden 1.
    • Looking at the keyboard, locate the eight clips that hold it in place.
  5. Toshiba Satellite C55-A5100 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55-A5100 Keyboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  6. Toshiba Satellite C55-A5100 Keyboard Replacement: adım 6, 1 resimden 1.
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  7. Toshiba Satellite C55-A5100 Keyboard Replacement: adım 7, 1 resimden 1.
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 1,025
