Ana içeriğe geç
Toshiba Satellite C55-A5100 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Toshiba Satellite C55-A5100 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Place laptop with the bottom of it facing up.
    • Remove the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Remove the 4mm Phillips #1 screw on the side of the now exposed area.
  5. Toshiba Satellite C55-A5100 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Remove the disc drive from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Any idea of how tall the drive is? Is it 12.7mm or 9.5mm tall?
Luis Alejandro Araúz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 353
