Ana içeriğe geç
Toshiba Satellite C55-A5100 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5100 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 RAM Replacement: adım 2, 1 resimden 1.
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Place the laptop with the bottom facing up.
    • Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite C55-A5100 RAM Replacement: adım 4, 2 resimden 2.
    • Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
  5. Toshiba Satellite C55-A5100 RAM Replacement: adım 5, 1 resimden 1.
    • Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
  6. Toshiba Satellite C55-A5100 RAM Replacement: adım 6, 1 resimden 1.
    • The ram chip will tilt up after the clips are released.
    • Using your fingers, pull the ram chip out at a slight angle.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 409
