Ana içeriğe geç
Toshiba Satellite C55-A5140 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5140 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Working from left to right, use plastic opening tool to lift keyboard up and out of recessed holding tray.
    • Continue to pry around the entire keyboard until it is loose enough to easily slide your fingers underneath the corners of the keyboard.
    • Once existing keyboard is removed, it can no longer be reinstalled. Be sure to have new keyboard available for installation.
    • Keyboard will make a snapping sound as it is freed from tray.
  2. Toshiba Satellite C55-A5140 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-A5140 Keyboard Replacement: adım 2, 2 resimden 2.
    • Using hands, gently pull keyboard out of device.
Sonuç
To reassemble your device, use tabs on new keyboard to snap into keyboard tray
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 575
