Ana içeriğe geç
Toshiba Satellite C55-A5286 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-A5286 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: adım 4, 1 resimden 1.
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55-A5286 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Carefully slide the optical drive out of its place in the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicole Zellers
265 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Hovde Fall 2018 IUPUI, Team S1-G5, Hovde Fall 2018 üyesi
IUPUI-HOVDE-F18S1G5
2 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 337
