Ana içeriğe geç
Toshiba Satellite C55-A5300 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5300 Battery Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-A5300 Battery Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-A5300 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Battery Replacement: adım 2, 3 resimden 1. Toshiba Satellite C55-A5300 Battery Replacement: adım 2, 3 resimden 2. Toshiba Satellite C55-A5300 Battery Replacement: adım 2, 3 resimden 3.
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 17
Her zaman: 479
