Giriş
This guide will help you if you need to replace the hard drive in your laptop. Replacing the hard drive will fix any issues caused by a faulty hard drive. It is very straightforward and can be completed regardless of technical knowledge or skill level.
Neye ihtiyacın var
With the Laptop off, turn it over.
The battery is located next to the screen hinges.
Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
Unscrew the screw on the back panel of the laptop covering the hard drive.
