Ana içeriğe geç
Toshiba Satellite C55-A5300 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5300 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-A5300 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-A5300 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • With the Laptop off, turn it over.
    • The battery is located next to the screen hinges.
    • Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
  2. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 2, 3 resimden 3.
    • Slide the tab identical to the first one on the right side above the battery pack to the right. This tab is spring loaded, so be sure to hold it.
    • Insert your tool or your fingernail into the notch just above the center of the battery pack, and lift the battery pack out of the device.
  3. Toshiba Satellite C55-A5300 Keyboard Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Unscrew the screw on the back panel of the laptop covering the hard drive.
  4. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tools to remove the panel.
  5. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the screw next to the hard drive using the PH1 screwdriver.
  6. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 6, 1 resimden 1.
    • Pull the silver tab connected to the hard drive up to take it out.
  7. Toshiba Satellite C55-A5300 Keyboard Replacement, Fan: adım 7, 1 resimden 1.
    • Using the PH1 screwdriver, remove the remaining screws from the back casing of the laptop.
  8. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 8, 1 resimden 1.
    • Use a nylon spudger or plastic opening tool to carefully wedge the casing apart and remove the back plate of the laptop.
  9. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 9, 2 resimden 1. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 9, 2 resimden 2.
    • Remove the 2 screws holding the fan in place.
  10. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 10, 2 resimden 2.
    • Detach the multi-colored wire connecting the fan to the motherboard and pull the fan out.
  11. Toshiba Satellite C55-A5300 Keyboard Replacement, CD Drive: adım 11, 1 resimden 1.
    • Remove the screw to the top right of the hard drive using the PH1 screwdriver.
  12. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 12, 1 resimden 1.
    • Use the plastic opening tool to wedge between the CD Drive and the laptop casing and gently pull it out.
  13. Toshiba Satellite C55-A5300 Keyboard Replacement, Keyboard: adım 13, 1 resimden 1.
    • The screws holding the keyboard in place have already been removed along with the back panel, so just push the keyboard out of the laptop by pushing your fingers through the holes under the fan and CD drive.
  14. Toshiba Satellite C55-A5300 Keyboard Replacement: adım 14, 1 resimden 1.
    • Once the keyboard is hanging out of the laptop, separate it from the device by pulling out the tab connecting the keyboard to the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
My A5302 has 1 screw near the ID sticker that secures the keyboard. Then just use the pry tool to work around the edge to pop it out and unplug. Always remove battery first
Guy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 725
