Ana içeriğe geç
Toshiba Satellite C55-A5302 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5302 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 693
