Ana içeriğe geç
Toshiba Satellite C55-A5310 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-A5310 Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: adım 2, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: adım 2, 2 resimden 2.
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Fan Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Fan Replacement: adım 4, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement: adım 4, 2 resimden 2.
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Fan Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement: adım 5, 2 resimden 2.
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
  6. Toshiba Satellite C55-A5310 Fan Replacement, Fan: adım 6, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement, Fan: adım 6, 2 resimden 2.
    • Take a nylon spudger and push the prongs so that it releases the RAM.
  7. Toshiba Satellite C55-A5310 Fan Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
  8. Toshiba Satellite C55-A5310 Fan Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement: adım 8, 2 resimden 2.
    • Remove the single .5mm JIS #000 screw.
  9. Toshiba Satellite C55-A5310 Fan Replacement: adım 9, 1 resimden 1.
    • Use the plastic opening tool to remove the keyboard from the laptop.
  10. Toshiba Satellite C55-A5310 Fan Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement: adım 10, 2 resimden 2.
    • Once the keyboard is popped out, use a spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
  11. Toshiba Satellite C55-A5310 Fan Replacement: adım 11, 1 resimden 1.
    • Remove thirteen JIS #000 11mm screws.
  12. Toshiba Satellite C55-A5310 Fan Replacement: adım 12, 2 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement: adım 12, 2 resimden 2.
    • Use a nylon spudger tool to lift up on all sides.
    • Once the panel has been loosened it will pop off.
  13. Toshiba Satellite C55-A5310 Fan Replacement: adım 13, 1 resimden 1.
    • Remove five 11mm JIS #000 screws.
  14. Toshiba Satellite C55-A5310 Fan Replacement: adım 14, 3 resimden 1. Toshiba Satellite C55-A5310 Fan Replacement: adım 14, 3 resimden 2. Toshiba Satellite C55-A5310 Fan Replacement: adım 14, 3 resimden 3.
    • Remove the four wires with tweezers.
    • Remove wires gently to avoid damaging them.
  15. Toshiba Satellite C55-A5310 Fan Replacement: adım 15, 1 resimden 1.
    • Lift from corresponding sides of the fan and it'll pop right out.
Sonuç
Robin
181 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 601
