Ana içeriğe geç
Toshiba Satellite C55-A5310 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: adım 2, 2 resimden 1. Toshiba Satellite C55-A5310 Optical Drive Replacement, Optical Drive: adım 2, 2 resimden 2.
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Optical Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite C55-A5310 Optical Drive Replacement: adım 4, 2 resimden 2.
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Optical Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55-A5310 Optical Drive Replacement: adım 5, 2 resimden 2.
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
Sonuç
Kari Rodgers
482 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 366
