Ana içeriğe geç
Toshiba Satellite C55-A5310 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-A5310 RAM Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-A5310 RAM Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-A5310 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 RAM Replacement, RAM: adım 2, 2 resimden 1. Toshiba Satellite C55-A5310 RAM Replacement, RAM: adım 2, 2 resimden 2.
    • Remove one JIS #000 screw.
    • This screw does not come out all the way, but you will still be able to open the back panel.
  3. Toshiba Satellite C55-A5310 RAM Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to pry the panel open. Be sure to do this on all four sides. Then the panel will lift off.
  4. Toshiba Satellite C55-A5310 RAM Replacement: adım 4, 3 resimden 1. Toshiba Satellite C55-A5310 RAM Replacement: adım 4, 3 resimden 2. Toshiba Satellite C55-A5310 RAM Replacement: adım 4, 3 resimden 3.
    • Take the nylon spudger, and push the prongs so that it releases the RAM.
  5. Toshiba Satellite C55-A5310 RAM Replacement: adım 5, 3 resimden 1. Toshiba Satellite C55-A5310 RAM Replacement: adım 5, 3 resimden 2. Toshiba Satellite C55-A5310 RAM Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
Sonuç
Kari Rodgers
482 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 380
