Giriş
A guide on how to replace the fan on your Toshiba Satellite C55-B5200 laptop.
Neye ihtiyacın var
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the single 4.6mm Phillips #0 screw securing the fan.
Use a pair of tweezers to unplug the fan from the motherboard.
Pull the fan out.
Bir başkası bu kılavuzu tamamladı.
