Ana içeriğe geç
Toshiba Satellite C55-B5200 Optical Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement, Optical Disk Drive: adım 3, 1 resimden 1.
    • Make sure device is turned off and unplugged
    • Failure to do so could result in electric shock
    • Use J0 Philips Head Screwdrivers to remove 13, 6.6 mm screws on back of device
  4. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: adım 4, 3 resimden 1. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: adım 4, 3 resimden 2. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: adım 4, 3 resimden 3.
    • Remove the remaining two, 6.6 mm screws to remove the battery
    • Use a plastic opening tool to lift and open the back
  5. Toshiba Satellite C55-B5200 Optical Disk Drive Replacement: adım 5, 1 resimden 1.
    • Lift and pull out disk drive
Sonuç
Bir başkası bu kılavuzu tamamladı.
Pablo Andrade
1.081 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G1
4 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 17
Her zaman: 720
