Ana içeriğe geç
Toshiba Satellite C55-B5200 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-B5200 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 RAM Replacement: adım 2, 1 resimden 1.
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 RAM Replacement, RAM: adım 3, 1 resimden 1.
    • Flex the metal retaining clips on the side of the RAM away from one another.
    • If done correctly, the RAM will pop out of its lock.
  4. Toshiba Satellite C55-B5200 RAM Replacement: adım 4, 1 resimden 1.
    • Pull the RAM out of the socket to remove.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Pablo Andrade
1.081 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G1, Nance Spring 2018 USF Tampa, Team S3-G1, Nance Spring 2018 üyesi
USFT-NANCE-S18S3G1
4 Üyeler
22 adet Kılavuz yazıldı
Bir Yorum
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
Andrew Kling - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 35
Her zaman: 1,331
