Giriş
How to replace the RAM on a Toshiba Satellite C55-B5200 laptop.
Neye ihtiyacın var
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
So the complete bottom panel doesn’t need to be removed to access the memory? The bottom panel that is held in place by another 8 screws?
