Ana içeriğe geç
Toshiba Satellite C55-B5302 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-B5302 Fan Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55-B5302 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Fan Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-B5302 Fan Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Fan Replacement: adım 3, 1 resimden 1.
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Fan Replacement, Fan: adım 4, 3 resimden 1. Toshiba Satellite C55-B5302 Fan Replacement, Fan: adım 4, 3 resimden 2. Toshiba Satellite C55-B5302 Fan Replacement, Fan: adım 4, 3 resimden 3.
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Fan Replacement: adım 5, 1 resimden 1.
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Fan Replacement: adım 6, 3 resimden 1. Toshiba Satellite C55-B5302 Fan Replacement: adım 6, 3 resimden 2. Toshiba Satellite C55-B5302 Fan Replacement: adım 6, 3 resimden 3.
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Fan Replacement: adım 7, 1 resimden 1.
    • You can now lift the fan out of the laptop.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 478
