Ana içeriğe geç
Toshiba Satellite C55-B5302 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-B5302 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Toshiba Satellite C55-B5302 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Hard Drive Replacement: adım 5, 2 resimden 1. Toshiba Satellite C55-B5302 Hard Drive Replacement: adım 5, 2 resimden 2.
    • The hard drive is held in place with a soft, blue rubber retainer. The retainer can be disconnected by pulling up on the two tabs at the left side of the hard drive in these images.
  6. Toshiba Satellite C55-B5302 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Gently pull the hard drive away from the connection to remove it from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 1,053
