Ana içeriğe geç
Toshiba Satellite C55-B5302 Webcam Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-B5302 Webcam Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement, Battery: adım 1, 2 resimden 2.
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 2, 2 resimden 2.
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Webcam Replacement: adım 3, 1 resimden 1.
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Webcam Replacement, Fan: adım 4, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement, Fan: adım 4, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement, Fan: adım 4, 3 resimden 3.
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Webcam Replacement: adım 5, 1 resimden 1.
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Webcam Replacement: adım 6, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 6, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 6, 3 resimden 3.
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Webcam Replacement: adım 7, 1 resimden 1.
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: adım 8, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: adım 8, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement, Screen Bezel: adım 8, 3 resimden 3.
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Webcam Replacement: adım 9, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 9, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 9, 3 resimden 3.
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Webcam Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 10, 2 resimden 2.
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Webcam Replacement: adım 11, 2 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 11, 2 resimden 2.
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Webcam Replacement: adım 12, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 12, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 12, 3 resimden 3.
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Webcam Replacement: adım 13, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 13, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 13, 3 resimden 3.
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Webcam Replacement: adım 14, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 14, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 14, 3 resimden 3.
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
  15. Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: adım 15, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: adım 15, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement, Webcam: adım 15, 3 resimden 3.
    • Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
  16. Toshiba Satellite C55-B5302 Webcam Replacement: adım 16, 2 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 16, 2 resimden 2.
    • Remove the two 3.1 mm Phillips #0 screws at the top of the screen.
  17. Toshiba Satellite C55-B5302 Webcam Replacement: adım 17, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 17, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 17, 3 resimden 3.
    • Pull up on and turn over the screen to expose the wire connecting the webcam to the screen.
    • Be careful not to pull up on the screen too far and damage the wire.
  18. Toshiba Satellite C55-B5302 Webcam Replacement: adım 18, 3 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 18, 3 resimden 2. Toshiba Satellite C55-B5302 Webcam Replacement: adım 18, 3 resimden 3.
    • Once the screen has been detached and turned over, remove the webcam from its place on the bezel.
  19. Toshiba Satellite C55-B5302 Webcam Replacement: adım 19, 2 resimden 1. Toshiba Satellite C55-B5302 Webcam Replacement: adım 19, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Carefully, take off the tape connecting the webcam to the circuit board using a set of tweezers.
    • Once the tape has been removed, you can disconnect the webcam from the wire completely.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Browning
310 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Henning Spring 2019 IUPUI, Team S1-G3, Henning Spring 2019 üyesi
IUPUI-HENNING-S19S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 1,539
