Giriş
Use this guide to remove the memory chip from your Toshiba Satellite C55-B5302 laptop. You will need a Phillips #0 screwdriver and a plastic opening tool. Make sure your laptop is unplugged and cool before you start. The memory chip is easy to remove and should take 10 to 15 minutes.
Neye ihtiyacın var
Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
