Ana içeriğe geç
Toshiba Satellite C55-C5240 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 2, 3 resimden 3.
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: adım 3, 2 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: adım 3, 2 resimden 2.
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 4, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 4, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: adım 5, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: adım 5, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: adım 5, 3 resimden 3.
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 6, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 6, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 6, 3 resimden 3.
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 7, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 7, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 7, 3 resimden 3.
    • Peel off the rubber hard drive mount.
  8. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: adım 8, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: adım 8, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: adım 8, 3 resimden 3.
    • Slide the disk drive to the right and gently lift up the disk out the laptop.
  9. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 9, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 9, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 9, 3 resimden 3.
    • Disconnect the 5 ribbon cables.
    • To remove, unlock the latch of each ribbon and pull it out.
  10. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 10, 2 resimden 2.
    • There is a wifi card underneath the large ribbon cable on the right.
    • Remove the plastic piece that covers the screw.
  11. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 11, 2 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 11, 2 resimden 2.
    • Unscrew the PH1 Phillips head 3.0 mm long screw holding it in.
    • Pull out the WiFi card.
  12. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 12, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 12, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 12, 3 resimden 3.
    • Disconnect the 4 regular cables.
    • Carefully pull the cable parallel to the board, not up or at an angle.
  13. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 13, 2 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 13, 2 resimden 2.
    • Unscrew the seven PH1 Phillips head 3.0 mm long screws that hold the motherboard in place.
  14. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 14, 3 resimden 1. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 14, 3 resimden 2. Toshiba Satellite C55-C5240 Motherboard Replacement: adım 14, 3 resimden 3.
    • Carefully lift the motherboard from the edges.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Abdel Feliciano Gonzalez
722 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G5
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 51
Her zaman: 7,056
