Ana içeriğe geç
Toshiba Satellite C55-C5240 Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Screen Replacement: adım 2, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 2, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 2, 3 resimden 3.
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: adım 3, 2 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: adım 3, 2 resimden 2.
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Screen Replacement: adım 4, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 4, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 4, 3 resimden 3.
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Screen Replacement, Screen: adım 5, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement, Screen: adım 5, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement, Screen: adım 5, 3 resimden 3.
    • Carefully disconnect these three cables.
  6. Toshiba Satellite C55-C5240 Screen Replacement: adım 6, 1 resimden 1.
    • Open the laptop at a right angle to make the later removal much easier.
  7. Toshiba Satellite C55-C5240 Screen Replacement: adım 7, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 7, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 7, 3 resimden 3.
    • Unscrew the four PH1 Phillips head screws on the hinges.
  8. Toshiba Satellite C55-C5240 Screen Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 8, 2 resimden 2.
    • Separate the screen from the rest of the laptop.
    • Make sure the cables do not catch on the bottom piece.
  9. Toshiba Satellite C55-C5240 Screen Replacement: adım 9, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 9, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, remove the two stickers on the bottom of the screen.
    • Unscrew the two screws underneath.
  10. Toshiba Satellite C55-C5240 Screen Replacement: adım 10, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 10, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 10, 3 resimden 3.
    • Stick the plastic opening tool underneath the screen bezel and run it along the edge of the screen.
    • Loosen each hinge separately, it would be more difficult otherwise.
  11. Toshiba Satellite C55-C5240 Screen Replacement: adım 11, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 11, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 11, 3 resimden 3.
    • Unscrew the four inner screws around the screen.
    • Leave the two outer screws on the top alone.
  12. Toshiba Satellite C55-C5240 Screen Replacement: adım 12, 3 resimden 1. Toshiba Satellite C55-C5240 Screen Replacement: adım 12, 3 resimden 2. Toshiba Satellite C55-C5240 Screen Replacement: adım 12, 3 resimden 3.
    • Mind the cable on the bottom of the screen.
    • Simply lift the screen out.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Angela Rodriguez
261 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G5, Nance Spring 2017 USF Tampa, Team S1-G5, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G5
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 2,435
