Ana içeriğe geç
Toshiba Satellite C55-C5268 Back Panel Replacement Guide
Neye ihtiyacın var
  1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Battery: adım 1, 1 resimden 1.
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: adım 2, 2 resimden 1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: adım 2, 2 resimden 2.
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Back Panel: adım 3, 1 resimden 1.
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: adım 4, 2 resimden 1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: adım 4, 2 resimden 2.
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: adım 5, 2 resimden 1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: adım 5, 2 resimden 2.
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ben Rounseville
471 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Catania Fall 2016 UMass Dartmouth, Team 4-1, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S4G1
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 30
Her zaman: 1,982
