Ana içeriğe geç
Toshiba Satellite C55D-A5108 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-A5108  Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108  Hard Drive Replacement: adım 2, 1 resimden 1.
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108  Hard Drive Replacement: adım 3, 1 resimden 1.
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108  Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108  Hard Drive Replacement: adım 5, 1 resimden 1.
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoffrey Souza
327 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G5
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 311
