Ana içeriğe geç
Toshiba Satellite C55D-A5108 Back Cover Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-A5108 Back Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Back Cover Replacement: adım 2, 1 resimden 1.
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Back Cover Replacement: adım 3, 1 resimden 1.
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Back Cover Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Back Cover Replacement: adım 5, 1 resimden 1.
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: adım 6, 3 resimden 1. Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: adım 6, 3 resimden 2. Toshiba Satellite C55D-A5108 Back Cover Replacement, Back Cover: adım 6, 3 resimden 3.
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kristen Gismondi
92.639 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.648 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 274
