Ana içeriğe geç
Toshiba Satellite C55D-A5108 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: adım 2, 1 resimden 1.
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: adım 3, 1 resimden 1.
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: adım 5, 1 resimden 1.
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite C55D-A5108 Keyboard Replacement: adım 6, 2 resimden 2.
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
Sonuç
Michael Medeiros
150 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G5
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 248
