Ana içeriğe geç
Toshiba Satellite C55D-A5201 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 2, 1 resimden 1.
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 3, 2 resimden 2.
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 5, 1 resimden 1.
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 6, 1 resimden 1.
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 7, 3 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 7, 3 resimden 2. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 7, 3 resimden 3.
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 8, 2 resimden 2.
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 9, 3 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 9, 3 resimden 2. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 9, 3 resimden 3.
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 10, 2 resimden 1. Toshiba Satellite C55D-A5201 Keyboard Replacement: adım 10, 2 resimden 2.
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Kari Byrd
614 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-5, Shaver Spring 2015 Baylor, Team 6-5, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G5
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 5,811
