Ana içeriğe geç
Toshiba Satellite C55D-A5304 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-A5304 Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that the laptop is disconnected from all power sources and turned off.
    • Start with computer upside down with battery slot facing up.
  2. Toshiba Satellite C55D-A5304 Fan Replacement: adım 2, 1 resimden 1.
    • Use the buttons of the sides of the battery to slide inwards and release the battery.
  3. Toshiba Satellite C55D-A5304 Fan Replacement: adım 3, 1 resimden 1.
    • Take the battery out.
  4. Toshiba Satellite C55D-A5304 Fan Replacement, Fan: adım 4, 1 resimden 1.
    • Open the back of the laptop using a pry tool.
  5. Toshiba Satellite C55D-A5304 Fan Replacement: adım 5, 1 resimden 1.
    • Once you see the fan, to make the cleaning process more convenient use a screwdriver to unscrew the 4mm screws on the fan.
    • To the immediate right of the fan the wiring harness is located. Disconnect this also to remove the fan.
  6. Toshiba Satellite C55D-A5304 Fan Replacement: adım 6, 1 resimden 1.
    • Use a microfiber cloth and/or compressed air to clear any dust or clogging.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Verre
211 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Petersen Spring 2023 UMass Dartmouth, Team 3-1, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S3G1
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 89
