Ana içeriğe geç
Toshiba Satellite C55D-B5206 Back Casing Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Toshiba Satellite C55D-B5206 Back Casing Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55D-B5206 Back Casing Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Back Casing Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55D-B5206 Back Casing Replacement: adım 2, 2 resimden 2.
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Back Casing Replacement, Back Casing: adım 3, 1 resimden 1.
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Back Casing Replacement: adım 4, 1 resimden 1.
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Back Casing Replacement: adım 5, 3 resimden 1. Toshiba Satellite C55D-B5206 Back Casing Replacement: adım 5, 3 resimden 2. Toshiba Satellite C55D-B5206 Back Casing Replacement: adım 5, 3 resimden 3.
    • Using fingers remove the casing.
Sonuç
Tayyaba
527 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-5, Bruce Fall 2015 CSU Fullerton, Team 2-5, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G5
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 27
Her zaman: 111
