Ana içeriğe geç
Toshiba Satellite C55D-B5206 Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-B5206 Fan Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55D-B5206 Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Fan Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55D-B5206 Fan Replacement: adım 2, 2 resimden 2.
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Fan Replacement, Back Casing: adım 3, 1 resimden 1.
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Fan Replacement: adım 4, 1 resimden 1.
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Fan Replacement: adım 5, 3 resimden 1. Toshiba Satellite C55D-B5206 Fan Replacement: adım 5, 3 resimden 2. Toshiba Satellite C55D-B5206 Fan Replacement: adım 5, 3 resimden 3.
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Fan Replacement, Fan: adım 6, 2 resimden 1. Toshiba Satellite C55D-B5206 Fan Replacement, Fan: adım 6, 2 resimden 2.
    • Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
  7. Toshiba Satellite C55D-B5206 Fan Replacement: adım 7, 1 resimden 1.
    • Gently lift the copper heat sink to make the fan more accessible.
    • The copper heat sink should not detach. Do not pull on it too hard.
  8. Toshiba Satellite C55D-B5206 Fan Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55D-B5206 Fan Replacement: adım 8, 2 resimden 2.
    • Maneuver the fan's bottom left corner above the copper heat sink.
  9. Toshiba Satellite C55D-B5206 Fan Replacement: adım 9, 1 resimden 1.
    • Cautiously move the white cable cover to allow for the fan to be lifted away.
    • Do not detach the white cable cover.
  10. Toshiba Satellite C55D-B5206 Fan Replacement: adım 10, 1 resimden 1.
    • Lift the fan approximately one inch upward from back of the laptop.
    • Detach the white cable connector from the connective port.
  11. Toshiba Satellite C55D-B5206 Fan Replacement: adım 11, 1 resimden 1.
    • Once the cable port is detached, lift the fan free from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tayyaba
527 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-5, Bruce Fall 2015 CSU Fullerton, Team 2-5, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G5
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 480
