Ana içeriğe geç
Toshiba Satellite C55D-B5206 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: adım 3, 1 resimden 1.
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 5, 3 resimden 1. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 5, 3 resimden 2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 7, 3 resimden 1. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 7, 3 resimden 2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 8, 2 resimden 1. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 8, 2 resimden 2.
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 9, 3 resimden 1. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 9, 3 resimden 2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: adım 9, 3 resimden 3.
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Michelle
175 İtibar
1 Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-5, Bruce Fall 2015 CSU Fullerton, Team 2-5, Bruce Fall 2015 üyesi
CSUF-BRUCE-F15S2G5
4 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
Thanks.. Really helped out..
SpeedyBlanco - Yanıt
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 4,829
