Giriş
In this guide we will show you how to safely remove the screen of your Toshiba Satellite C55D device. If the screen of your device is cracked, it will be best to remove the screen for replacement. Removing the screen is a delicate process because of how fragile the material is. We aim to provide you with a step by step tutorial on how to easily remove the screen.
Neye ihtiyacın var
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Use a spudger to pry the top corner of the casing by performing an upward motion.
Continue to remove the casing using your hands.
4 farklı kişi bu kılavuzu tamamladı.
